2016 Ford Transit Van - 5" In A-Pillars, Sony GS9, Helix Director
SkizeR
My friend Steve, who i have met a short while back through this great hobby that is car audio, recently acquired a 2016 Ford Transit van that he intends to use for auto-sound competition. He contacted me to do some work on it when he found out i was going into the business myself. He wanted me to do the A-Pillars, which house Satori MR19PNW-4, which is a 5 inch midrange. He also wanted me to fabricate a housing for the Satori TW29BN-B tweeters, and install the Sony RSX-GS9 Radio as well as the Helix director. Steve had some very specific "wants" for the pillars. These were to 1) aim them on axis. 2) give them at least a liter of airspace. 3) Get them as deep and as wide as possible. 4) wrap them in Alcantara to match the soon to be dash wrapped in Alcantara, or a suede dash mat. and 5) do this all while keeping the protrusion of the pillars at or under 3.5 inches from the factory pillar surface in order to stay in MECA's Modex class. Steve saw them as wants, and if they didnt work out, so be it. But, i saw them as needs. No compromises.
First step, finding out what im working with, and how i want them to end up. I knew that since they were 5 inches and were going to be on axis and wont protrude more than 3.5 inches, that they would need to be recessed. Since theyre recessed, theres going to need to be a cut out, or "scoop". The black marker lines are drawn in a way so that when sitting in the driver seat, the marker lines look like it completes the circle of the blocked speaker perfectly. This will be the cut out.
Here it is with it cut out, but not at the angle of the drivers head rest, so in this picture it doesnt show the whole speaker. I should have gotten better photos
Heres what i was working with behind the pillars. since theres an airbag, i was limited to building the enclosure only in the triangle area below it.
After all testing and playing with ideas for mounting, this is how the pillars ended up.
As you can see, there was a metal tab that was stealing some prime real estate. In order to get the mids as deep and as wide as possible while still staying within the 3.5" rule of MECA's Modex class, this needed to be cut. There were 3 other tabs that held the a pillar in place so this one wasnt a big deal. The windsheild and dash were covered to prevent any accidents or metal shavings getting anywhere.
Also, getting the airspace would have been easy if we used that pocket seen in the photo. That would have made installation/uninstallation a huge PITA. I ended up not using it and still getting over a liter of airspace.
Tab removed.
Lower pillar area taped off and everything to prep for glassing.
Fiberglass layup of the back side.
After the first layup cured, i installed the pillar and made a mold of the dash onto and through the pillar to connect the two molds to make the pillars and the mold one piece. Afterwards i removed them and trimmed the edges.
After trimming off the nasty edges, they were reinstalled, and the rings were aimed and attached.
After they were attached, some old thermal t-shirts were sacrificed.
Side note, the eAsy fillers are certainly not a bs overpriced/rebranded product. They truly are great.
Passanger pillar after glassing,filling, and sanding. Lots and lots of sanding.
Another side note: when i did the mold of the dash and attached it to the first mold/pillar, i didnt install the pillar all the way at the top so it was leaning in a bit. This was so when installed fully, the mold of the dash was lifted up from the dash about 1/8th of an inch. Reason for this was so uninstallation/reinstallation would be much easier. The way these uninstall is you pull them out from the top. If i didnt do this, pulling out from the top would have put a lot more stress on the pillar/enclosure and flexed the pillar in the areas where they are attached. This can cause issues in the future. to combat the gap left over while making it able to have wiggle room for install purposes, i used a compliant strip of 1/8" dynaliner CCF. It can be compressed to almost nothing so it can fill the gap when needed, and still give you wiggle room during install.
Installing of the Sony RSX-GS9.. Steve supplied the Metra kit for his car, which houses a double din. we did the Sony Unit on top of the director. This is the bracket i made to hold the director. Steve suggested mounting with velcro for ease of uninstallation/reinstallation, and the director doesn't really have any other easy/good ways to be secured.
Both installed into the Metra brackets
The left over space was filled with mdf/filler and wrapped in Alcantara to match the pillars and soon to be dash.
Filled and test fitted.
Steve supplied some molds he previously made of the upperdoor/quarter glass area to make "sail panels". This is where he wanted the tweeter mounted. i used his molds and just build them up to be a bit stronger. They are secured to the door with 2 rivnuts per door and a 1/4-20 bolt. Unfortunately, i used two different memory cards in my camera throughout the build, and i formatted the one i accident that had most of the pics of the sails build progress. Im sure steve will upload some once they are installed.
This is the only other picture i have of it. In this photo i was in the process of making a seam to wrap them, also in Alcantara.
Sony RSX-GS9 and Helix Director installed with the 2 inserts that were mounted with magnets.
Pillars all finished and installed. This angle is from a little to the right and behind the driver headrest.
Here is a diagram outlining the enclosure that sits beneath the fabric. the outline and everything inside it is all usable airspace by the driver. Just the part that is behind the driver measured out to be around 1 liter using the old squished up packing peanuts method. I'm thinking after driver displacement theres still a hair over a liter
I think the reflections are making a prediction.. imaging outside of the car //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks for taking a look, i am extremely happy with how this all came out. I cant wait to see pics (and in person) what it looks like (and sounds like) when the dash is done and the sails are installed. Thank you again Steve, i am very excited to see and hear it all when its finished and im rooting for ya out in the lanes! Team SSQ!
That is really beautiful craftsmanship there. Really gorgeous pillar modification. You should make molds for some of the most popular car audio vehicles and start manufacturing them, like say, a 2010 Yukon!!
Looks really good! Love the detail on the build. Very simplicity in sound like. Good job!
Thank you! SiS more so does their pillars to live up to their name.. (usually) simple //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thank you. and i wish making molds were that easy. unfortunately its not. plus, every install/driver setup/goal needs something different. there is no one answer to everyones needs. i wish though lol
wow man thats a lot of work for a van., if all peeps could take out windshields i guess this would be very common looks cool..
Thank you thank you. But, the windshield doesnt need to be removed for this.
SkizeR
SkizeR
New York
SkizeR
