2009 GMC Acadia speaker issue
mcgrew77
Ok, I have had a problem with my rear drivers side speakers ( door and third seat) cutting in and out on my 2009 GMC Acadia. It has the Bose 10 speaker system. When I turn the volume up they will cut back on but this does not last as they will cut out again later. I replaced the head unit, the speakers and the amp. This has not solved the problem. I am at my wits end with this! Does anyone have any idea what the problem could possibly be?
Check your wiring. Make sure the wire jacket hasnt been worn away and isnt grounding/shorting somewhere. Try running speaker wire directly from your amp to your speaker without running it through the door or anything. Just as a test. If you do that and you dont have any issues. Its your wiring.
The speakers might also be telling you they're getting ready to **** the bed. I had the same problem in my 07 passat, changed all my speakers haven't had an issue since
mcgrew77
mcgrew77
Dallas TX
baked52420
vegang
vegang
