2008 Ford Sport Trac Adrenalin & JL Audio Setup
  • 2
Psyence
Customized
447
Canada
Hey all!
Bought myself a new vehicle about 6-7 months ago and after some pondering I am ready to get going.
Here is a list of equipment that I will eventually be installing.
Dynamat Extreme
Audiocontrol LC7
Knukonceptz Wiring & Distribution
JL Audio 570-CSi Front and Rear Components
JL Audio 13 TW5 in a Sealed Enclosure
JL Audio 500/1v2 Sub Amp
JL Audio 300/4v2 Component Amp
Thats all planned for now. I am going to use the Audiocontrol LC7 to wire the system into the stock deck w/ MS Sync. I like the stock look, so for now im going to run the deck I have.
This vehicle is terrible for subs, the previous Sport Trac I owned I ended up cutting the rear 60% seat to match the other 40% side and building a custom fiberglass ported enclosure for a JL 13W7. This being a brand new vehicle i'm going to try to work some magic outside of cutting apart the upholstry, etc. Im sure down the road it will turn into more of a custom setup, but for now im going stealth on the install. Nothing should be visible.
Pics to follow!
I haven't purchased the 500/1v2, but I was considering the 1000/1v2, depending on space. Will probably go that route.
Any recommendations on enclosure size for the TW5 getting 1000W?
it will take the 1000 as long as its good clean power
i was running a 1000/1v2 to the pair i had and they could have used more power
another guy local here is running 1100 i think to a single one no problem
.8 - 1ft
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
And it works great with android phones, you can connect, and what can you say about android radio tape recorders are now leaders in functionality...
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
411
Psyence
Customized
Psyence
Canada
bones22
    Apr 28, 2024
    Apr 28, 2024
