Just all depends on what you are peaking at...... I raised my box tuning by 5hz, and ended up peaking lower by 3hz:crap:meehhh I hope better than 146. I did a 147.4 with my xxx 15 with a jl1000/1 running to it. and the box was tuned at 32 htz... at 4.3 cubes. I really hope 6 12's will do a little better than that with the box around 50 htz lol
did you just cut the port shorter, which also made volume go up on the box //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifJust all depends on what you are peaking at...... I raised my box tuning by 5hz, and ended up peaking lower by 3hz:crap:
No we added more to the port versus the 12"s. Went from 194 to 200did you just cut the port shorter, which also made volume go up on the box //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
how many cubes is the box as the port does seem pretty small for SPL....
well got metered as it sits. 147.8 sealed, 151.7 in the kick and this is at 64 htz. I will be doing a rebuild on the port to lower the tuning. Should get close to 150 sealed.
You dont know shit leg rider:fyi:those subs will be giving out on you after a week if not less. and when burping just go till the meter registers 3 to 4 secs should do.
Port on driver side would probably meter better if you could do it. My wall had the port up top, it was 196sq in.so I am going to add a little depth to the box. Give it a little more airspace. should see about 10 to 11 cubes. and Should I do a port completely across the top? or just go a little larger. or wider really. Can't do much larger than 6 inches high. but I could do up to 30 inches wide. giving me around 180 sq inches of port... Just wondering if doing a larger port will give me any better increase id dbs...?
