2005 Crew Cab F150 build suggestions
BLACKBEARD
Hey guys new to the forum just wanna get some feed back on how I should proceed with my build. I've got a pretty decent knowledge of car audio just wanna get a second opinion, only doing mids and highs for now. At the moment I have:
HU: Pioneer AVH5800 BHS
Amp: Soundstream Tn4.900d
Midbass: Four Selenium 6W4P 8ohm
Tweeters: None at the moment need some advice
As of right now, temporarily, I have the mids on the left and right side ran parallel down to 4ohms to channel 1-2 on the front rca input. The amp has some decent crossover capabilities and so does my headunit. I want to run an active system I just dont know if i should use my headunit or the amp to achieve this. Would it be a good idea to keep the mids on the front rca input and the tweeters on the rear rca input. Each side has its on crossovers built in the amp.
I'm mounting the amp behind the rear seat like so. The back wall has two layers of sound deadening and 3/4 mdf for mounting. I used an amp I had laying around to mock it up
BLACKBEARD
BLACKBEARD
Orlando, FL
BLACKBEARD
