2005 Chevrolet Trailblazer
nathanprice
I drive a 2005 Chevrolet Trailblazer LT with a 4.2L inline-six engine.
I have done the big 3 upgrade, and have a stock 150 amp alternator.
First I designed the box in sketchup.
It will have a removable port face for replacing subs and changing the tuning.
Box progress(Lizard for scale)
Drilled holes for the bolts that will hold the top on.
Test fit/look.
Paint!
It was first primed with KILZ Original oil based. I was going to paint it black, but I didn't get enough black paint, so I mixed it with the white primer until I had enough. Not the color I wanted, but can be painted again later.
Test fit
Wow that is huge.
This is my daily driver, so it couldn't interfere with the seats.
The top was bolted on using star washers on top and bottom to prevent them from vibrating loose.
Each sub terminal was wired using a bolt and some washers and nuts.
I bought four Massive Audio TKO124 at a local car audio shop (support local businesses).
I ran a PAIR of 14awg speaker wire PER terminal.
The amp. Rockville Audio RXD-M4, $150. Puts out 1000w CEA @ 2 ohm. Has been dyno'd by Dereck at oldschoolstereo.
A pair of 14AWG speaker wire per terminal and 4AWG power/ground wire.
nathanprice
nathanprice
Alabama
nathanprice
BP1Fanatic
BP1Fanatic
