2002 honda accord v6 EX how much can i....
michaellane
well as of right now i run a elemental design nine.1 amp 1200watts rms....i was wondering 1 minute at a time could i run 2 nine.1's at comps if i keep me foot on the gas while im getting metered? im trying to put up some higher numbers but my car is comp. stock as far as electrical...oh i may add a batcap but not tooo sure...please all info would be great...and the amp would be removed after comps
well i can do the big 3 but i cant do anything else since my cars still under warranty....but even if it dropped low would it still put out more than my single amp? and if i burp them i only need to hold decent voltage for like a few seconds right
u don't need to put your foot on the gas and all that. with stock batt, alt, big 3, and 1/0ga. my voltage on my civic never dropped below 10.5V with the same power as 2 nine.1's (2400wrms). So you'll be fine since your alt is bigger than mine. Also, the big 3 is easy to uninstall, do it! you can pull it out before the lease is up with no problems
hhhmmmm well if i can get another nine.1 pretty cheap ill do it...but will running 2 mono amps put me in a different class? this weekend i was in the 501 and up trunk class...since my amp does like 700 at 4ohms
well im just tring to do like local comps thats all....i could keep my same amp and do a better battery up front and a different box just for comps where the port fires into the car with the seats down...does that sound like a good start?
michaellane
michaellane
tx
loopkiller
