Is there any way to run a power cord through a 2001 ford taurus SE and into the trunk without having to drill any holes through anything? if not what is the easiest and best place to run the power cord to the trunk? Thanks for your help.
There is a small grommet above/behind the fusebox underneath the drivers side dash. The biggest you can go is 4 gauge. Its not easy to get to, but its the best way to go with new gen taurus'. Good luck.
crhye250r is right... it's not the easiest to get to... but it's gonna be a lot easier than findin a good spot to drill and run your wire through... take down the fuse box and pull back the rubber mat & carpet and there is a small grommet behind it if u want bigger than 4 gauge u'll have to drill the hole bigger...
Glad to help out. Also, its good that someone else concurs. Fellow installer I assume? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
good thing you guys let me know now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
my buddy has a 98 tarus, and im about to put some 1\0 or 4awg in his car hnoes:
eaither going with 4, or slicing that opening with a nice fat drillbit //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif and putting a new gromet on there.
