2001 Mercedes SL500 wiring help
Are you refering to the power cables to the front battery or the RCA and speaker wires? Does it have the consumer battery in the trunk, and how big is it?
Yes, the power wire for the amp and the wire from the radio to the backup camera. The battery is in the trunk and I don't see anywhere to run these two wires into the trunk.
The battery in the trunk is a normal sized battery, the power wire is 4 gauge.
Most common practice is to remove the door sill trim on either side and run it under it. Then wires run under the seat edges and carpet. Sometimes difficult but always doable. Do not give up. You may even have to remove the seat/s. Are you not mounting the amp in the trunk?
I have run all head unit wires through the center console area and all speaker wires under the door sills. All wires are behind the seats at a shelf where a backseat would go if there was one. I am mounting the amp in this area so my trunk will remain available for use.
kslbenz
kslbenz
Mount Holly, NC
