gckless
Here is my first real build. Took a lot of prep work and research. Mostly satisfied with the visual results so far. Haven't set gains yet, need to do that tomorrow. Right now they are only 1/4 of the way up, and the sub I have not really turned up that far.
Work wasn't too bad, but there were a few things I missed. I installed the baffle upside down. If you look close you will see the sub is off center. I also forgot to stain the top and bottom of the inside of the port.
Oh, lol, almost forgot. I had to redo the speaker connections. The first time I did it, I got everything done, turned it all on, and the head unit was going into protect mode. I was like ****, I know I didn't connect anything backwards. So a quick Google search revealed how much of an idiot I am. I dove back in behind the head unit, and turns out I wired the 9 conductor speedwire from the 4 channel amp to the head unit, instead of to the speakers lol. So had to redo those, luckily I had spare butt connectors.
Besides that, I think it turned out alright. I wanted to try to stain it, as I don't see that alot. Plus I figured if it didn't turn out well I could go back and carpet it. I probably won't be doing that again though. Too much work. Carpet is so much easier.
Some pictures are attached.
View attachment 26534495View attachment 26534494View attachment 26534496View attachment 26534497View attachment 26534498View attachment 26534499View attachment 26534500
