2000 Dodge Truck Setup Good or Bad
Clownzer
4
TX
Here are the power ratings so yall wont have to look them up:
AMP:
Description: Class D Monoblock Subwoofer Amplifier
Patented Technology: High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
Differential-Balanced Input Topology: 1 pair of inputs
On-board Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
Bass EQ: Single-band parametric with variable boost up to +15dB and Remote Bass Option
Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
Subs:
Free Air Resonance (Fs): 28.5 Hz
Electrical “Q” (Qes): 0.497
Mechanical “Q” (Qms): 8.458
Total Speaker “Q” (Qts): 0.469
Equivalent Compliance (Vas): 1.18 cu. ft. / 33.4 liters
One-Way, Linear Excursion (Xmax)*: 0.60 in. / 15.2 mm
Reference Efficiency (no): 0.149%
Efficiency (1W/1m)**: 83.7 dB SPL
Effective Piston Area (Sd): 51.4 sq. in. / 0.0332 sq. m.
DC Resistance (Re): 6.30 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 400W
Driver Displacement: 0.068 cu. ft. / 1.9 liters
Net Weight: 14.4 lbs. / 6.4 kg
Cool thanks I was wondering if that would would be able to power the subs both in Dual 4 ohm. I guess I will also need to update my stock speakers as well any suggestions on those?
Cool thanks guys some people are saying I could save money by going with other equipment like this:
JL is a good company, and that would be a nice set up. that being said I personaly feel JL is way over priced. That amp is like 350 online and those subs are about 260 ea. I would do something like this
Amp-275 shipped
http://cgi.ebay.com/MB-QUART-REFERENCE-RAA1000-1000w-RMS-MONO-CAR-AMPLIFIER_W0QQitemZ9743090099QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Subs-165 ea
http://www.soundsplinter.com/rli_ignition_series_8_inch_and_10_inch_diy_subwoofer_drivers.html
what do yall think
i would go for the updated seteup.
but i would run a different amp, maybe a Phoenix Gold Xenon 1200.1 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif but thats just cause i lolve my xenon amp. Or you could get a few Xenon X400.1 or X600.1 since they are dead cheap.
theirs tons of options, you could go with something from http://www.edesignaudio.com(full system in one stop), yuou could get subs from my fav sub maker http://www.imagedynamicsusa.com, could get some Type-R, could do tons of things with tons of amps and subs.
just go listen to some at local shops see what you like, check out prices on ebay. Or just start searching on hear.
Clownzer
Clownzer
TX
marley1
