2 tone carpet
KilluminatiDre
Ok so I want to have the carpet on the face of my box where the subs mount a different color than the rest of the box. What would you guys suggest as the best way to carpet this with least visible amount of seams? Especially when going from the first color to the second.
Make another front baffle piece that can fit around the sub's when mounted, carpet or vinyl that piece the different color. Then carpet the box and make sure to carpet the front baffle too. Then you'll have no visible seams on the front and you can mount the custom colored piece right over top of it. You can use magnets to hold it on or screws
Is there any way I can do this and still use glue for the double baffle? Or are screws or magnets the only options?
Best would be to do just a trim piece for cosmetic only IMO. You could probably even use just 1/4" stock. If you want/need double baffle do that on the box and keep your different-color trim piece separate. You'll want to wrap the carpet around the back of the cosmetic piece and overlap an inch or so around the back side to look nice so gluing that to the rest of the box is sort of out.
KilluminatiDre
KilluminatiDre
Japan
KilluminatiDre
