Justintoxicated
just set your gain and you will be ok. I'm not sure what the most power you can run to a W6 is, but you can ALWAYS turn your gain down a bit to run it at RMS.Thanks for all the help guys. I got my amp in the mail today. I am looking at the performance verification certificate and it shows 714 @ 2 ohms and 975 @ 1 ohm.Will 1 10w6 hold that much. Also I noticed that the 10w6 recommend space is only .6cu ft. So I could put 2 in the 1.41 space I have. I am just worried that will be to much for such a small car. Please let me know what you think thanks
DLS is your another great option but you seem to want to stick with a more mainstream sub (I understand as it is hard to find reviews on them). The DLS has less mounting depth (which is the issue for me) although they are I believe about $400 each.
You could always buy one W6, and then try adding the other one later if it is not enough.
