blkmrideon22s 10+ year member CarAudio.com Elite 593 0 Boone NC Apr 23, 2009 #1 which subs would be better to run with a sundown saz 3000d or a saz 3500d Click to read more...
sundownz Pro Seller Supporting Vendor 11,349 95 North Carolina Apr 23, 2009 #2 Completely different subs - what are your goals ? Sealed ? Ported ?
T Towncar 10+ year member CarAudio.com Veteran 4,816 5 who knows Apr 23, 2009 #3 Like mentioned about, apples to oranges.. The hdcs are geared more for spl/ streetbeat setups, but still sound decent.
hrtbrk1 5,000+ posts 1ManWreckinCrew 5,906 14 Boomer Sooner, OK Apr 23, 2009 #4 isnt the z better in sealed?
80INCHES 5,000+ posts EPICENTERGLUED 2 ME 7,123 23 WESTCHESTER, NY Apr 23, 2009 #5 u still didnt answer the question...sealed or ported? 80
sundownz Pro Seller Supporting Vendor 11,349 95 North Carolina Apr 23, 2009 #6 isnt the z better in sealed? Click to expand... It is flexible - either works great.
K kmanian 5,000+ posts CarAudio.com Veteran 8,890 63 Grand Cayman Apr 23, 2009 #7 DO NOT mix Sundown amps with AQ subs, your car will not work properly if you do.
Kastlez_ 10+ year member CarAudio.com Veteran 3,555 17 Bay Area, CA Apr 23, 2009 #8 DO NOT mix Sundown amps with AQ subs, your car will not work properly if you do. Click to expand... //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
RidnClean 5,000+ posts Love 4 Money 8,890 1 Washington Apr 23, 2009 #11 z15 gets my vote, just cause im not a fan of HDCs tuning.
S slim2fattycake 10+ year member rolling right along 2,241 19 In the Stars Apr 23, 2009 #12 They can be tuned a little high and still get low fairly easy.
Lakota 5,000+ posts Doesn't Know $hit 6,277 1 Louisville, KY Apr 23, 2009 #13 That amp isn't enough for 2 hdc318's. The one that I have has really stiff spiders and it takes some juice to get it moving.
01 S 10 10+ year member LOUD 4,397 0 Central Florida Apr 23, 2009 #14 saz3500 should be plenty for copper hdc3's... the z15's are rated at 1000w rms. why not go with nightshades? i realize they are more expensive. but between the two you have listed, the 2 18"s "should" be louder due to cone area.
B basebalz13 10+ year member D-money 4,254 4 roanoke, virginia Apr 23, 2009 #15 the Z15 will still get loud i bet //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif depends on box
