2 Sundown SA-8 d4
cman0655555
1. Product:
2 Sundown Audio SA-8 Dual 4
2. Specs:
The SA-8 is easily one of the most powerful 8" sub-woofers on the market today. It features a unique motor - which is actually a bit different from the rest of the SA line - designed to get the most performance possible from an 8" woofer in it's price bracket. A smaller diameter 2" coil was utilized so that a larger spider could be mated to the driver for extended excursion capability. The SA-8 is capable of around 2 inches peak to peak mechanical throw with 1.25" of that being linear coil travel.
If you are shopping for powerful bass in a compact package the SA-8 is for you. They are equally at home in SPL installations where enclosure volume is at a premium.
Specifications:
D2 Model :
RE: 3.28 ohms (series)
FS: 41.6 Hz
Qes: 0.513
Qms: 6.606
Qts: 0.476
Le: 2.778 mH
Vas: 3.285 L
BL: 17.138 N/A
Cms: 83.341 um/N
Mms: 175.654 g
Sens: 78.476 dB @ 1w/1m
BL^2/RE: 89.5
3. Description/Condition:
Both subs are 8/10. One has a very small scuff on the surround. One had about an inch of the surrond that came unglued from the basket. I glued the surround back down with some ca glue from fi and it works fine now. Sub is still 100% functional and I used it daily. If you use the gaskets it looks brand new and you would never know it was there. It was actually hard to get in a picture.
4. Price:
160+actual shipping. Located at 40361 so depending on your location will depend on the cost.
Will work out a price if you want to pick these up locally. I can deliver or meet you if you are within a reasonable distance.
190 with box. Will only sale the box locally unless you want it and are willing to pay to have it shipped.
Box specs are 1.7819 cubes with full 17’’ 4'' aeroport tuned at 34. 27wide x 12tall x 13deep. Pretty much brand new aeroport been mounted in 1 other box temporarily.
Really only need cash atm being I plan on upgrading.
Only trades I am looking for is a set of nice 10's such as FI SSDs Q, SSA icons, Sundown Z Series or similar style subs. No 12s 15s or 18s have no use and can’t fit them.
5. Pics
Pictures of the scuff
Pics of the part of the surround that came unglued
Pictures of the coils
I know you said no trades for 12, 15, or 18's but you didn't mention other 8's.... Soooo, trade for 2 DD 1508's D4? lol
Thanks for the offer but I would be in the same scenario I am in now and that is needing to upgrade. Good catch though I did leave that out.
cman0655555
cman0655555
Carlisle, KY
cman0655555
