2 Sundown NS-1 amps
  • 2
serjr711.
Antioch,Ca
2 Minty Sundown NS-1 amps
Rated power output
----RMS power, 2 ohm linkable/dual mono
13000W x 1CH
----RMS power, 1 ohm mono
6500W x 1CH
----RMS power, 2 ohm mono 3600W x 1CH
----RMS power, 4 ohm mono
1800W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm
Fuse rating 600A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Near mint condition, comes with both remotes.
1325.00 shipped EACH. NO TRADES OR PAYMENT PLANS. NOT IN A HURRY TO SELL.
Included in price. (I know how awesome these amps are, no need to post it in this thread, also no glws or wishing etc.. NO BS.)
Never been repaired, 1 is a yr old, other is 10 mos.
IMAG0009 by cartman38, on Flickr
IMAG0008 by cartman38, on Flickr
IMAG0007 by cartman38, on Flickr
IMAG0006 by cartman38, on Flickr
There’s no question that that setup wouldn’t bump like hell. Those SALT amps are killer. If the new Origin subs are as good as the ETA subs were...
479
10
serjr711.
serjr711.
Antioch,Ca
serjr711.
    May 18, 2024
    May 18, 2024
