2 subs or one sub ?
trunks9_us
so a dealer/installer was telling me that 2 subs will be better than one sub both equally the same power total 1 sub total power = 2 subs total power. He said it would be better cause of more cone area and it will hit hard also is this true? This will be for a ported box and will it be louder and hit harder?
Only time they may not be is when you don't have ENOUGH space to PROPERLY do 2 12s, but have sufficient room for one. Better to have one proper sized box for one sub then a box to small for 2 woofers.
ic now well i might do 3 jbl w12gti in my trunk or i can do one dd9512? which would be louder i am guessing the 3 12s. I just have to make sure i have enough room for 3 12s which the dealer said i could do 2 15s but it would take the whole trunks so 30 vs 36 i think i might have enough room. also i could always do 3 10s if i needed to since i need ot run a 4ohm load so what u think i should do 1 big 12 or 3 smaller size rms 12 or 3 tens? or 2 15s?
normally the more surface area ur subs displace the louder it will be.. however if the single sub will hit a littler faster then the 2 if they together = the same power as the single sub... wut are the subs u are considering???
lol what?
someone has to sig this^^ .//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
and what-Cotjones v2?? thank god. this has to be good.
Back to the OP, I'm actually considering going to single 15 setup instead of the 2 i have now. Ithink i can get the same output from the single sub, just because it gonna be a better quality and louder sub. but its all in the install.
trunks9_us
trunks9_us
college station tx
Grinder1989
