9 99greengt 10+ year member Member 43 0 St. Louis Mo. Feb 2, 2008 #1 can you run two subs on a mono amp? if so how do you wire them up? Click to read more...
SilverSquared 10+ year member Fat guy on the GROUND. 2,407 62 Southeast Louisiana Feb 2, 2008 #2 Like any other amp. As long as you are at, or above the recommended ohm load of the amp. What amp and subs?
OP 9 99greengt 10+ year member Member 43 0 St. Louis Mo. Feb 2, 2008 Thread Starter #3 I was just wondering cuz i have a two chan. and my friend wants to do a system and i wasn't sure. if you hav a mono at 1000 watts is that for both or 500 each?
OP 9 99greengt 10+ year member Member 43 0 St. Louis Mo. Feb 2, 2008 Thread Starter #4 does anybody know?
outspoken 10+ year member CarAudio.com Elite 1,599 0 Between The Golden Gate And The Bay Bridge Feb 2, 2008 #5 it would be 500 each, but make sure your subs are wired at an ohm load that the amp is stable for...
OP 9 99greengt 10+ year member Member 43 0 St. Louis Mo. Feb 2, 2008 Thread Starter #6 so if the amp can do 1000 watts at 2ohm than wire the subs at 2ohm and that would be 500 each?
S Stevefrech 10+ year member Junior Member 13 0 Canada Feb 3, 2008 #7 wat are the VC's on ur sub D2, D4?
OP 9 99greengt 10+ year member Member 43 0 St. Louis Mo. Feb 3, 2008 Thread Starter #8 D4 unless I sell these and get two type Rs than I can get either.
DBDRAGGUY 10+ year member CarAudio.com Veteran 2,287 0 BURLINGTON,KY Feb 3, 2008 #9 can you run two subs on a mono amp? if so how do you wire them up? Click to expand... post the model # on the amp and subs and someone can give a more detailed answer.
BEAVER.989 10+ year member CarAudio.com Elite 791 0 Michigan Feb 3, 2008 #10 Two D4 subs can be wired to achieve a 1ohm load or a 4ohm load. If the amp you own wants to be ran at 2oms, you will need either 2 D2 subs or 2 SVC 4ohm subs.
OP 9 99greengt 10+ year member Member 43 0 St. Louis Mo. Feb 3, 2008 Thread Starter #11 they say if they are wired in parallel than it presents a 2ohm load.
BEAVER.989 10+ year member CarAudio.com Elite 791 0 Michigan Feb 3, 2008 #12 they say if they are wired in parallel than it presents a 2ohm load. Click to expand... Each. Now parallel two of them and it's 1ohm.
OP 9 99greengt 10+ year member Member 43 0 St. Louis Mo. Feb 3, 2008 Thread Starter #13 oh ok i get get it you wire the subs together thats what I wasn't sure about.
