(2) SAZ-3000D's
tholley
2 Sundown Audio 3000D's
7/10 cosmetically
10/10 mechanically
These amps were hooked to a very good electrical system and never saw under ~13.5.
Most people around here know the specs but just for anyone who doesn't these amps are very under rated and many people have ran them daily at .5 ohms.
The SAZ-3000D is the big brother to the acclaimed SAZ-1500D amplifier. The SAZ-3000D delivers incredible amounts of power for the most demanding power-users and SPL competitors. This amplifier is not for the weak of heart and was designed to deliver earth shaking power to the biggest and most powerful subwoofers on the market. Sundown Audio only recommends this amplifier for experienced users with an upgraded alternator and additional batteries* due to the enormous power output potential.
SPECIFICATIONS:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* Wired Remote Controller
* MSRP $1549 USD
----RMS power, 2 ohm linkable/dual mono
6000W x 1CH
----RMS power, 1 ohm mono
3000W x 1CH
----RMS power, 2 ohm mono 1600W x 1CH
----RMS power, 4 ohm mono
800W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 53(H) x 594(L)mm
Price is $550.00 a piece shipped anywhere in the continental U.S.
** No trades unless you'd like to trade for a more powerful amp + cash on my end
I have sold to a few members on here and on soundsolutionsaudio.com
Price is shipped
Could you PM me some more pics of that battery and amp you have in your car? also what car is that and howd you stack them..That **** makes me horny looking at it very nicely done lol
All I have... it's in a tahoe.
tholley
tholley
u.s.
RAM_Designs
