2 RE Audio SE12DR's box help *NOOB* lol
dwaine
I am going to be getting 2 of these and run them in a parallel for a 1ohm load...
http://redirectingat.com/?id=42X123&test=off&url=http%3A//www.cardiscountstereos.com/catalog%2520page.asp%3FProduct+%2523%3DSE12D4
I just need help on a box... I would like to go ported and tuned around 30Hz...
What size box do I need and, how much do you guys think it would cost to get a box built to those specs?? If someone is local and can build one for me, that would be greatly appereciated!! In the Central Texas area...
Thanks... BTW I have a Scion tC
The size you need depends on how much power and space you have available. Generally, the more power you have, the smaller you can build your box. However, a smaller box will also drop off after tuning much more quickly than a large box.
Anywhere from 2-3 cubes per driver should be adequate for that tuning.
dwaine
dwaine
254 TX
SSS 18734
