2 ppi pro104s and 3 jl audio w0 10" 1sinlge cab 03 dodge ram
ok. im going with the ppi pro104s. im looking at either a mb quasrt dsc 1500.1d or hifinics brutus bxi 1610d. any suggestions
link me up to those ppi pro's, and what are you going to pay for them? The JL W0's are bottom of the line subs, I am pretty sure the Pro's are way better... plus are they the flat piston ones?
i got them for 119 a piece.
Features:
•E-Glass Flat panel
•Tri Radius symmetrical edge surround
•Dual gap motor
•Single flat interlaced Conex Spider with loop stitched tinsel leads
•3” High temperature Copper voice coil wound on an Aluminum voice coil former
•Custom Cast Aluminum frame
•Rubber wrap around two way mounting gasket
•Custom terminals
•Dual voice coil
•TriCool™ - Voice coil cooling system
•Custom impedance jumper system
Specifications:
Model Number PRO 104 PRO 124
MSRP $499.99 $549.99
Thiele/Small Parameters
Fs (free-air resonance, Hz) 32 39
Vas / Liter / ft3 17.8 / 0.63 21.5 / 0.76
Qts (total driver Q) 0.65 0.92
Re (DC resistance, ohms) 5.9 5.9
IMPEDANCE dual 4 Ohm dual 4 Ohm
Efficiency (1W @ 1M, dB) 81 dB (1W/1M) 83 dB (1W/1M)
Xmax (one way linear excursion, mm.) 24 26
Driver Physical Dimension
SIZE 10" 12"
Mounting depth (inches *) 7 - 1/2" 8 - 1/2"
Enclosure Details
1. External dimensions calculated for 3/4" building material
2. Includes port and speaker displacement
3. Volumes given are net tuning volume
jlm2002
jlm2002
Tyler
Chrispy
