2 ohms or 4 ohms?
CentralFC
So my subwoofer (Alpine Type R 12") is dual voice coil 4 ohm. Now what I'm confused with is it's wiring down to 2 ohms (for 500 watts RMS). I wired down to "2 ohms", but is that per voice coil, making it 4 ohms, thus leaving me with only 300 watts RMS? If so, does that mean I'd have to wire it down to 1 ohm, making it 2 ohm total?
Basically what I'm asking is if the ohms are per voice coil, or total. Any help would be great! This would really make things clear.
the wattage doesn't change that the sub can handle when it's wired on any ohm. so when you wire it up to 2ohms you can still run 500 to it. it just depends on the amp you're feeding it with. it's a total number cause you wire them both together.
CentralFC
CentralFC
Wisconsin
tenbux1970
BP1Fanatic
BP1Fanatic
