Sold 2 Mtx Elite Amps
Apollo220
New POst with pics with my name and date ....
1.)Mtx te1501d specs Birthsheet gives it 1750+ Comes with bass knob 320 shipped
TE1501D Specifications
# OF CHANNELS 1
MINIMUM SINGLE CHANNEL IMPEDANCE 1
CLASS D
AMP OPTIMIZED FOR SUB
POWER SUPPLY Semi Unregulated MOSFET
(Pat. No: US05598325) x
THD + NOISE (1 Watt) ≤.5%
FREQUENCY RESPONSE (-3dB) 20Hz-200Hz
SIGNAL-TO-NOISE RATIO (1 Watt) 69 dB
OVERLOAD PROTECTION x
THERMAL PROTECTION x
14.4VDC POWER 4 Ω 500
2 Ω 1000
1 Ω 1500
Peak Power 3000
BI-LEVEL INPUT (RCA Connection) Low Level x
Hi Level w/ Smart Engage (Pat. No: US06556683) x
INPUT SWITCH Input Sense 100mV-1V/1V-10V x
GAIN CONTROL MONO - 100mV-10V x
CROSSOVER LOW @ 40Hz - 200Hz, 24dB x
SUBSONIC @ 30Hz, 12dB, Defeat x
EQUALIZATION QUASI Parametric: Boost/Cut ± 12dB, Freq. 30Hz-80Hz x
OTHER FEATURES Remote Subwoofer Level Control Parallelable x
Prizm EFX With Demo Mode x
POWER CONNECTION 1/0 Gauge Direct Input With 4 Gauge Direct Cap Input x
DIMENSIONS Height 9-5/8"
Width 20-11/16"
Depth 2-1/2"
2.) Mtx Te1004 Birthsheet 1050rms. specs: With bass knob 320 shipped
TE1004 Specifications
# OF CHANNELS 4
MINIMUM SINGLE CHANNEL IMPEDANCE 2
CLASS A/B
AMP OPTIMIZED FOR FULL
THD + NOISE (1 Watt) ≤.25%
FREQUENCY RESPONSE (-3dB) 20Hz-20KHz
SIGNAL-TO-NOISE RATIO (1 Watt) 75 dB
14.4VDC POWER 4 Ω 125 X 4
2 Ω 225 X 4
4 Ω Bridged 450 X 2
2 Ω Bridged 950 X 1
Peak Power 1900
Input Select 2/4 Channel x
GAIN CONTROL Stereo - 100mV-10V x
Mono - 100mV-10V x
CROSSOVER HI, 12dB / LOW, 24dB MONO @ 40Hz-350Hz, DEFEAT x
RCA OUTPUT SUM, Front/Rear x
EQUALIZATION THUNDER EQ: BOOST 0-18dB,
FREQ. 40Hz x
ARC: CUT 0-15dB, FREQ. 200Hz x
Dual Mono Output x
POWER CONNECTION 4 Gauge Direct Input With 8 Gauge Direct Cap Input x
Width 20-11/16"
Depth 2-1/2"
Apollo220
Apollo220
Columbus, GA
Apollo220
