NissanKicker
Honda-on-22-Nissan-on-20
Hey, I have everything that I need as far as on paper... I was just wondering if ANYONE ( Knowledgeable ) could give me anymore advice, pointers, or point out something that might go wrong with this design.
... I REALLY WOULD LOVE FOR SOMEONE TO SKETCH ME A MODEL... I REALLY WOULD APPRECIATE IT!!!!!
HERE WE GO!
MA HK12x2 Spec'd enclosure ( Ported ):
Cuft: 3cuft
Hz: 38hz
Sq Port: 4x4
Sq Port Length: 14.5"
Number of Ports: 3
Max Dimensions ( 99 Nissan Sentra ):
External Dimensions: 42"L x 22"D x 14"H
Internal Dimensions: 40.5"L x 20.5"D x 12.5"H
SUBWOOFER CUTS!
(2) 11.5" for the sub holes...
BOX CUTS!
Top: 14 x 42 x 22
Bottom: 14 x 42 x 22
Front Wall: 42 x 12.5
Back Wall: 42 x 12.5
Left Side Wall: 20.5 x 12.5
Right Side Wall: 20.5 x 12.5
* NOTE *
... Front wall will have the three ported centered on the bottom, in the middle.
Example:
2 Ports will be on the bottom in the middle, and the third will be centered in the middle stacked on top.
( Think of a PYRAMID, and you'll get the picture )
PORT
PORTPORT
^^^^^^^ LIKE THAT.... Exactly!
PORT CUTS!
* Each port external dimensions is 4" x 14.5"
Top: 4 x 14.5
Bottom: 4 x 14.5
Left Side Wall: 2.5 x 14.5
Right Side Wall: 2.5 x 14.5
* NOTE *
Remember! There are 3 ports. All are IDENTICAL ( Triplets )
To get DIRECTLY in the middle, it'll be:
42" MINUS 8" = 34"...
NOW
34" DIVIDED BY 2 = 17" on each side of the ports
To get DIRECTLY in the middle for the single stacked port, it'll be:
8" MINUS 4" = 4"...
WHICH MEANS
2"s will be on each side of the stacked port, making it centered.
TOTALING
A PERFECT PYRAMID!!
Here is a quick lil' sketch, to give you an IDEA of what I'm picturing in my head.
HERE WE GO!
Cuft: 3cuft
Hz: 38hz
Sq Port: 4x4
Number of Ports: 3
SUBWOOFER CUTS!
BOX CUTS!
Top: 14 x 42 x 22
* NOTE *
Example:
PORT
PORTPORT
PORT CUTS!
Top: 4 x 14.5
Bottom: 4 x 14.5
* NOTE *
NOW
8" MINUS 4" = 4"...
WHICH MEANS
TOTALING
A PERFECT PYRAMID!!
