2 M3Mojo15's with vx2200d amp
3kracing
So I just picked up 2 M3MOJO 15's and a VX2200D amp. Its going into a 2007 sonata. Will the amp be able to get everything out of the subs? Would I hear any difference if I added a second vx2200d amp (any extra db's?)
Thanks!
LOL NO!!!! those subs dont even get loud hardly off of 1000wrms daily, they will take 2kw daily!!! 1000wrms to each on the M3 MOJO 15s will make them just laugh, they start singing around 1600wrms and yell at 2000wrms, and die at 3000wrms..lol kick *** subs also!!!
Plus that amp is rated at 1ohm right?? if so you can only get 2ohm or .5ohm load with the pair, and either 1ohm or 4 ohm out of each one, because they come quad 1ohm, or dual 2ohm only on the MOJO M3 15s!! So two of those amps would be nice!!
Ok, would 2 VX2200D's be good enough? I'm guessing I'd have to get another battery too
By the way, these are the best forums! You guys reply the fastest and seem to know the most!
No, I was with one of my friends thats a girl yesterday and she was looking at my system and said it was small. So I put off getting a body kit and decided I want to try and hit 140db's. I bought them from a friend, got everything for 625. Ok so another VX2200D should be good and then what else will I need. New battery? 0 gauge wiring?
definatley 0/1 wiring.. and get enough for Big 3... then definatly another batt, if u even plan on running 2 amps.. look for a deka intimidator g31 batt.
i have never heard my system looked small.. not since i was 16 anyways.. i got 1 15" doing 145.8 from a trunk
Lol well I am 16 so //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. I had a pair of kicker comp vr's in the kicker box with a kicker 750zx amp. What do you mean enough for big 3?
Would it be alright to get an amp like the MA4000D and use it along with my VX2200D? Or do I need to have two of the same amps?
Definitely 2 of the same amp, maybe look into trading the VX2200D and cash for one huge amp.. I'd recommend about 5k coming from someone feeding 3-4k to a pair for daily.. For competing, i would run 3-4k to a single mojo.. and i only have the 12 inch version, but the output is amazing //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ok, what would be the best amp for me to get? (Within reason). With running 3-4K to each mojo what kinda DB's do you think I would be looking at in a 7cubic foot ported box in a 2007 hyundai sonata?
3kracing
3kracing
USA
3kracing
