Crucified
what amplifier would go best to get the most out of them? I drive a 2009 Dodge Ram Crew Cab, so the subs would go under the rear seats.
Specs of Subs:
# 800 Watt MAX (1600 Watt PAIR)
# 400 Watt RMS (800 Watt PAIR)
# Impedance: Single 4 Ohm
# Frequency Response: 25Hz-350Hz
# Shallow Mount Round Wofer That Delivers Extreme Bass With Minimum Depth
# Updated Ultra-Rigid
# Dark Gray Injection Molded Polypropylene Cone for Clearest Bass Response
# Cone Bracing and Venting
# Special Four Layer Voice Coil Provides Extreme Power Handling
# Spiralead Tinsel Lead Technology
# Ventless, Solid Pole Design Assists in Direct Rear Wall Mounting
# Spring Loaded Binding Posts
# Steel Adapter Plate
# Double Stitched Surround
# Updated Cosmetics and Front Gasket
# Mounting depth: 4-3/8"
Also if anyone knows of a good box fitted for my truck please let me know!
Specs of Subs:
