JL audio 8W0 great condition look brand new amp is JL audio E1200 also in great condition verything works perfect
SPECS
* Nominal Diameter: 8 inches (200 mm)
* Continuous Power Handling: 75 Watts
* Voice Coil: 1.25" diameter, 4-layer, Kapton former
* Available Configurations: 4 ohm or 8 ohm (Single Voice Coil)
* Xmax (one-way, linear): 0.27"-0.29" (6.8-7.4 mm)
* Sealed Enclosure Range: 0.30-0.60 cu.ft. (8.5-17.0 liters)
* Ported Enclosure Range: 0.60-1.00 cu.ft. (17.0-28.3 liters)
* VRCtm Technology: YES
Number of Channels 1 - Mono
RMS Power (4 ohms) 120 watts x 1 channel
RMS Power (2 ohms) 200 watts x 1 channel
RMS Power (1 ohm) Not Stable
Bridged RMS Power Not Bridgeable
Total RMS Power Output 200 watts
Peak Power Output 400 watts approx.
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable
THD at Rated RMS Power
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 50 - 200 Hz
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio >104 dB
Channel Separation N/A
Bass Boost 0 - 6 dB
Bass/Gain Remote N/A
Fan Cooled No
Fuse Rating 25A
Cosmetic 9.5 out of 10
Mechanical 10/10
Looking for 125 shipped for the both subs and amp.
SPECS
High-pass (HP)
Subsonic Filter N/A
Bass Boost 0 - 6 dB
Fan Cooled No
Fuse Rating 25A
Mechanical 10/10
