2 JL 12 W7's needs some insight
  • Thread starter CjInCal
  • Replies 0
  • Views 426
CjInCal
I have 2 JL Audio 12 W7's and would like to put them on a 2 channel amp. Now Im confused about what OHMs it will be running at only because I am a newb to all the stereo Biz stuff. The JL 12 w7's are SVC 3 ohm speakers. Im just looking for an alternative to buying the actual JL Amps because of costs.
Does this amp look like a good fit for the subs?
Will it supply the right amount of power to the subs at the correct OHMs?
So since it is a 2 channel amp does that mean it will still run at 3 OHMs ?
What does OHMs do for the system, I mean whats better to have Higher or Lower Ohms?
LANZAR VIBE286 2 Channel 4000 Watt High Power MOSFET Amplifier
Details
2 x 1000 RMS at 4 OHMS
2 x 2000W MAX at 4 OHMS
1 x 4000W MAX at 4O HMS Bridged
2 x 1650W at 2 OHMS
Electronic Crossover Network
Bass Boost Circuit
2 Ohms Stereo Stable
Anti-Thump Turn-On
Soft Turn ON/ Off
High & Low Level Inputs
Advanced Protectin Circuitry
Remote Control Bass Booster
Dimensions: 11.06''W x 2.24''H x 21''L
T.H.D:
S/N Ratio: > 90dB
Channel Separation: >65dB
Freq. Response: 15 Hz - 35KHz
CjInCal
CjInCal
San Diego, Ca
CjInCal
Mike Mccabe
