Sold 2 JBL BPx2200.1 +++$720.00 shipped each+++
Speakerman
Don't touch my willy
My email and MSN is bsbl83@cs.com
AIM – yackidy yack yac
For sale are a pair of JBL BPx2200.1 amplifiers more than capable of pumping out 2400 Watts rms at any ohm load from 1 – 2. These amps use Crown technology similar to the technology used in the massive JBL 6000 watt amp. I’m selling them because my car was broken into and I got scared everything would be stolen.
Sorry but prices are not really negotiable
Specs copied from the JBL website:
BPX2200.1
2200 Watt Parallel/Bridge Subwoofer Amplifier
2200 Watt Parallel/Bridge Subwoofer Amplifier with Dynamic Bass Optimization Circuit.
• Unlike conventional mono subwoofer amplifiers that only deliver their maximum power into a single impedance, the BPX1100.1 and BPX2200.1 are two-channel amplifiers that can be bridged to deliver double the voltage of a single channel into impedances between 2 and 4 ohms. The two channels can also be connected in parallel - that''s right, parallel - to provide double the current of single channel into impedance below 2 ohms. This feature is patented and unprecidented in car audio amplification. Thanks Crown!
• Slope-selectable variable electronic crossovers - Both the BPX1100.1 and BPX2200.1 is equipped with a variable electronic crossover capable of setting the slope rate at 12dB or 24dB per octave. The crossover adjustment range is 32Hz - 320Hz.
• Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications. Frequencies below an enclosure''s tunign frequency can be attenuated, preventing damage to the subwoofer and allowing the amplifier's power to be better utilized.
• High Effective Damping Factor - Both the BPX1100.1 and BPX2200.1 have a high Effective Damping Factor. The result is better subwoofer control and lower distortion.
• Both the BPX1100.1 and BPX2200.1 come equipped with a remote bass level control allowing you to optimize bass output for specific music or preferences from the driver's position.
• Full-range preamp outputs - In the event that multiple amplifiers are used in an application, this feature allows for streamlined system hookup. No high-loss Y-adapters or splitteres needed.
Power Output650 watts RMS x 2 channel at 4 ohms
and ≤ 1% THD + N
2450 watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1% THD + N
1810 watts RMS x 1 channel at 1 ohm,
Signal-to-Noise Ratio 67 dBA (reference 1 watt into 4 ohms)
Dynamic Power2940 watts at 4 ohms
Effective Damping Factor 6.28 at 4 ohms
Frequency Response22Hz – 302Hz (-3dB)
Maximum Input Signal7 V Maximum Sensitivity250 mV
Output Regulation.12 dB at 4 ohms
Dimensions (H x W x D)2-9/16" x 21" x 12-1/4"
MSRP U.S. $$1599.95
Speakerman
Speakerman
College Station, Texas
Speakerman
