2 HDS212s or 1 HDS315
dev199505
US
I wanna upgrade not sure which route to go I have an infinity reference 1211a rated 854w@4oh and 1300@2ohm currently have an HDS215 so the HDS315 sounds most budget friendly since I can just use the same box. Or is there something else you guys would reccomend
Sent from my Z812 using Tapatalk
Save for an hdc3 15 if you want a real noticeable upgrade. You'll want to upgrade power later.
Right now I have HDS215 wires to 4ohms so if I get the HDC I'd have to wire it to 2ohms correct? Amps not rated for 1ohm but curious to see if it'll hold up to it
I'm gonna be buying an expedition and retiring the bronco to the state so I'll have 700-1200 to spend on the system depending on how much the state gives me
With a $1200 budget what would you guys reccomend expedition will have big 3 and 150ah AGM under hood otherwise all stock
dev199505
dev199505
US
Jeffdachef
