2 Fi BL 15s
so then let me rephrase,
would i need to do any electrical upgrades to my car to power the amps that would be needed to power the subs?
try 4 2608's
fyi subs dont require electrical upgrades.......
adding amps to your car may add reason to do electrical upgrades... and 4 2608's would
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Dont listen to the guy above he crazy for considering 4 2608's for 2 BL's.. One of them will do. You can get away with just a battery in the rear. I dont think there is need for anything more than that.
wow, i dont know and yet i have used bl's.... ok lol
you use 1 of those amps and you will be disappointed. if you strap 2 and run at .5 ohms you might be ok but i wouldnt suggest it.
thank you thats what i was thinking do you think I should get D1 or D2?
BUMP!
What Ohm should i get? D1 or D2
you dont worry about that yet
start at the faq gain a little knowledge before even thinking about wasteing your money
and wasteing it you will be doing
before even considering those subs you need to think about amps
and before amps think about upgradeing you elec (ie. big altnator,couple batts,couple yes a couple runs of 0awg power and ground )
and before all that headunit,sound damping,door speakers,etc
and last but not least maby you dont want to do all that and you are on a budget so grab a pair of tens,amp and a 8 gauge kit from wally world
not trying to talk smack but you do not seam to know that much where you need btl's from the get go
If you use the 2608, I would recommend that you do the "big 3" and add a batt in the rear. A larger alt isn't needed. Since that amp makes its power @1ohm then you should get D1 subs, that will allow you to have a 1ohm final load for the amp
nchilds21
nchilds21
Falls Church, VA
UpGradde
