2 DC Audio 5.0k's
Budget_Ballin'
TEAM DC
2 Dc Audio 5k's with bass knobs and cords
Features Voltage 5.0kw
Output power (RMS) 4 ohm 14.4V 900W x 1
2 ohm 2,300W x 1
1 ohm 5,000W x 1
1 ohm 16V 6,000W x 1
1 ohm 18V 7,300W x 1
Input Sensitivity 6V~0.2V
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Bass Boost Variable dB 0-9dB
Frequency Response Hz 15-270
Signal to Noise Ratio dB 100
Damping factor 150
Efficiency @ 4ohm % Over 90%
THD @ 4ohms Less than 0.1%
Fuse Rating 500 Amps
Linked Fuse Rating 1000 Amps
Indicator Power Yes
Protection Yes
Clip Yes
Speaker & power terminal Mold Type Yes
Power Gauge 0Ga
Heatsink Length inch/mm 25.59"/650mm
Heatsink Width inch/mm 9.38"/66mm
Heatsink Height inch/mm 2.35"/59.6mm
About as mint as you can get for being used. I'd say 9/10 cosmetically since they've been mounted and used and 10/10 mechanically. Always ran strapped and on great electrical.
$900 + shipping each--NO TRADES!
Will ship via UPS Ground.
Thats a good price for the condition it is in //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Killer amps that do above rated //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif GLWS!
Budget_Ballin'
TEAM DC
Budget_Ballin'
Southern Ohio, United States
jaeguerra909
BP1Fanatic
BP1Fanatic
