2 ch amp, different ohm loads per channel?
orangecounty1
will that hurt anything? like i have an 8 ohm mid hooked up in the passenger door, and i had the same one in the drivers, but im working on mounting my door panels now for the 8 6.5s, so i took the drivers door mid out for now. if i hook up like 4 mids on the drivers door (2 ohm load total for channel 1) and the other side is still running that 8 ohm mid on channel 2, will that hurt anything?
and no its not permanent like i said im working on getting my baffle mounted so i can glass it, once i get the drivers done, the other door should be easy
its a sundown 100.2 btw
orangecounty1
orangecounty1
Tampa, FL
orangecounty1
