2-bxi2607d strapped?
why is that? If i parallel the subs inside the box then series them to the amps i will get a final impedance of 2 ohms or 1 ohm per amp. What would be wrong with that?
One dual2......2amps....parallel sub....strapped.... .5 each amp
Other way........2ohm per sub
okay lets see.
- 2 bxi 2607 strapped to 2 dual 2 ohm subs= great design.
2 dual 2 ohm subs (series the voice coils)= 4 ohm per sub
parallel both sub = 2 ohm
2 bxi2607 strapped nominal load = 2 ohms.
Perfect match in my opinion.
okay lets see.- 2 bxi 2607 strapped to 2 dual 2 ohm subs= great design.
thats exactly what i was thinking. just keep the gains down a bit and it wouldnt be a problem. 2-2607d is more than enough power to run 2-bls so i dont have to worry about getting more power i just wanna run a common chamber box and not have to worry about gain matching. plus i can get these amps pretty cheap.
That would be 1 ohm to each amp, not 2.
Noo...it would be 2ohm
Parallel sub - .5ohm
Series sub - 2ohm
Both strapped of course
Strapped means two amps powering the same set of speakers. In this case, if you parallel/series the subs together for a 2 ohm load, then hooking BOTH amps to this one 2 ohm load, then you are NOT going to get 2 ohms at EACH amp. 1 ohm nominal to each.
Whoops...i was meaning 1 sub
rain377
rain377
Detroit, Michigan
Anonymous
