(2)Batcap 2000
dbass
Wi
The Model 2000 will provide the energy to generate more SPL than any other battery weighing 75 lbs or less, other than our own brand.
The Batcap 2000 is a 50 amp-hour, 1500 cycles at 30 %
The Model 2000 makes a GREAT Electric Car Battery at 0.6 kilowatt-hour.
[ Standard Model Batcap X2000 ]
[ 12 volts........ 6.5“ x 7” x 6” ]
[ Weight ........ 34 lbs. ]
one on the left is older, a year old the other one i just got at the begining of the year. both are floating around 12.5-12.6 they have been sitting in my kitchen/living room for over a month and holds the charge great.
$150 for the new one $140 for the older shipped pick up is cheaper minus $10 off the price posted. dont really need to sell both but if someone needs both and have something decent to trade we can make it both. Trades are considered. looking for 6.5 components or 6x9's also looking for a batcap 400.
i have the original box for the one i bought at the beginin of the year and one can go into that the other i will have to find a box for it, will go thru ups.
left one
right one
Amazing batts here. VERY small and HUGE power!!!!
I was running 2 Deka 9a31's then went to 2 of these Batcap2000's. The 2 batcaps fit in roughly the same area as 1 Deka 9a31. And I gained 0.3dB.
I'm running 2 DD M2a's @ 1.5ohm strapped. Pretty much eliminated headlight dimming also.
thanx for the input.
lol, **** would have loved it when i was into competing, dont have any use anymore. im downgrading. thanx tho
more info
50 Ah Reserve Capacity
700+ Cranking Amps CCA
1500 Amps for 3 Seconds
2000 peak amps
---------- Post added at 08:47 AM ---------- Previous post was at 08:47 AM ----------
more info
2000 peak amps
heres sumthin i found googling. and if you need more input click on the link. WTB Batcap 2000's - Realm of Excursion
Im sure they both have their ups and downs
ok lets start with the Deka 9A31:
Price = 157.60 + shipping ( mine was only 185 shipped) *with dicount code*
AH = 100
RC= 190
CCA= 800
CA= 1000
weight = 69lbs
Dimensions: 13L x 6.75W x 9.5H
Completly sealed, maintenece free, ect..
Batcap 2000
Price= About 300 shipped -depending on where bought from
AH= 50
RC= N/A
CA= 2000
weight= 34lbs
Dimensions: 6.5” x 7” x 6”
Completly sealed ect..
Comparing the 2 :
Price: Deka is almost half the price so you could basically buy 2 for the price of 1 batcap 2000
AH: deka has double the amp hours
CA: batcap has 1000 more cranking amps
RC: cant compare.. cant find anything on the batcap
Weight: deka is 35lbs heavier , so if you need a light load in your car go batcap.. if not worried about weight go deka
Demensions: deka larger, batcap smaller
As i said they both have their ups and downs. Im personally going to run 4 deka intimidator 9A31's in the back because i need a large reserve for my daily playing and for bass race and db drag. On the other hand you may see an increase using the batcap 2000 for burps ect.. its all in what you are using it for.
dbass
dbass
Wi
Imtjnotu
BP1Fanatic
BP1Fanatic
