2 amps. no output. how do I hook them up?
1 amp to each sub? If so, switch the neg and pos speaker wires on one of amp and you should be good... pretty sure its a Phase issue . When you hook the second sub up its moving the opposite of the other and there canceling each other out...... this is if your saying you have 2 subs and an amp to each one.... let me know
I did that samr issue. I took the positive of one sub. Left its negative and put the positive on the other amp.
What do you mean?. Don't think you did what I was sayin
If there is a sub to each amp then hook one up like you said where is sounds the best. ( one sub to one amp) ...Then when your going to hook the wires from the other sub to the other amp, hook the wire you were going to put into the neg of the amp into the pos of the amp and pos into the neg. Know what I'm saying?
35thStangGT
35thStangGT
United States
frogcase2002
