2 amps in parrallel?
jgarder
hey i have two MA audio 15HXC's these subs are 4ohm DVC's
and then i have 2 CADENCE TX-A750D 750 WATT amps... that are 1 ohm capable
i belive these amps are strappable and i would like some links regarding how to link these things up! but also
i was wondering if there is a way i can wire up the 2 amplifiers to the 2 subwoofers and acheive 1 ohm.
I would like some links to websites please.. and also any risk involved (perhaps its tough on amplifiers... ) im just a moron who needs some help making a loud system.
So i guess those are my questions and any help would be great
If your cadence is like my Cadence TXA-1000D amp, if you were to strap the two TXA-750D amps the stable impedance level for the amps would be 2ohms. IF you wired two 4ohmDVC subs together you can ONLY achieve 1 ohm or 4 ohm impedance. Since the specs for the TXA-750D is
1 x 275 Watts @ 4 Ohm
1 x 375 Watts @ 2 Ohm
1 x 600 Watts @ 1 Ohm
WHEN STRAPPED -
1 x 550 Watts @ 8 Ohm
1 x 750 Watts @ 4 Ohm
1 x 1200 Watts @ 2 Ohm
if you wired both of your subs to the amps(when strapped) to a 4 ohm impedance you would only get 750 watts. You could try to wire them down to 1 ohm when the amps are strapped(not a good idea) but your amp could go into protection mode, and there is a possibility of it getting f***ed up. If the amps will handle the 1 ohm impedance than you should be ok, but doubtful.
Wiring Setups for amplifiers/Subs=
http://www.the12volt.com/caraudio/woofer_configurations.asp
That Site has ALOT of stuff on car audio just go thru the menus
So your saying.. that since the amps support being 1 ohm each.. but technically arnt rated to be strapped at 1 ohm.. its quite possible they will work fine.. and also quite possible i could ruin a amp.... i like those odd's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif but am i correct to assume that i can try 1ohm strapped and be pretty safe.. also keep in mind this isnt a Competition car.. just a drive around and have wild bass car.
u can try to run them at 1 ohm strapped BUT MOST LIKELY they will go into protection and wont turn on until the impedance is lowered.
jgarder
jgarder
billington
Oinkypig
