btballer38
Product: 2 alpine swx-1243D
Specs: Power Handling
* Power Range: 500 - 1000 Watts
* RMS Power Handling: 1000 Watts
* Peak Power Handling: 3000 Watts
Dimensions
* Mounting Depth: 219 mm (8.6'')
* Mounting Diameter: 277 mm (10.9'')
* Displacement: 0.194 cu. ft. (Front Mount)
* Added Volume: 0.079 cu. ft. (Reverse Mount, Magnet Out)
General
* Frequency Response: 24Hz - 200Hz
FEATURES
Diaphram
* Material: Kevlar RohacellA? Layered Composite
* Design: 1-Piece Parabolic wtih Vented Force Transfer Assembly
Surround
* Material: Injection Molded SantopreneA?
* Design: High Amplitude Multi-Roll (Patent Pending)
Spider
* Material: NomexA?
* Design: Mirrored Progressive
Voice Coil
* Material: 220A?C Aluminum Wire on Twin-Wall Aluminum Former (Patent #6,292,079)
* Design: 6-Layer 4I? Voice Coil with Inner/Outer Winding
Motor Structure
* Pole Geometry: Compound Radius Curve (Patent #6,639,993) with T-Drive
* Configuration: Billet Copper Shorting Sleeves with Heat Dissipation Plate (Patent Pending)
Frame
* Material: Cast Aluminum
* Design: Perimeter Vented Exo-Frame (Patent Pending) with Integrated Spider Landing (Patent #6,678,387)
Terminals
* Layout: One Side
* Design: Insert Terminal Blocks with High Current Voice Coil Configuration Jumper
Tinsel Leads
* Design: Reinforced Layer Spider Integration (Patent #6,810,988)
Gasket
* Design: Concealed Mount Design with Front/Rear Sealing Gaskets
Description/Condition: If you are looking for a high-quality subwoofer with the most accurate and precise in-vehicle subwoofer performance, then look no further. Alpine's 2nd generation state-of-the-art Type-X Subwoofers are your answer. With the advanced motor structure and new sound of these subs, you will experience higher efficiency, lower heat creation while maintaining superb sound, so you can really crank up the bass.
condition 9/10 (cause there used) no marks or scratches on surround
looking to trade for 2000 watt rms 2 ohm sub or subs, dosent matter on size of woofer.
thanks for looking!
Dimensions
General
FEATURES
Diaphram
Surround
Spider
* Material: NomexA?
Voice Coil
Motor Structure
Frame
Terminals
* Layout: One Side
Tinsel Leads
Gasket
thanks for looking!
