2-8" ports too much?
not for an 18 in an spl box.
It ends up being right around 20in^2 per ft^3...if you're going for spl then that's fine. If you're going for daily your sub will unload very easily below 40hz.
So does this seem like it would yield the best results?
And there should be at least 4" of clearance for each port, right, I mean between ports and walls
8 inches clearance if you can get it. these are actual flared aero's i assume.
Yes, flared aeros.
So I thought it was 4"? Seems like that would let the port breathe like it should...Or 4" on the sides, and 8" from the wall looking through the port...?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Yes, flared aeros.
i always try to keep them away from any wall, as much as the port is wide. so a 4 inch port, i would attemp to keep it away from either wall. if the enclosure doesn't allow that, then i do as much as possible at least.
Yes. I love chopped and screwed music.
C'mon, man, I'm not that much of a noob
wait. if this isn't an spl box, then you have issues in my opinion. first off, that box is too small for an 18, and a 45hz tuning isn't better for any type of music.
edit: jerk. you and your white typing.
mugen08
Win aplenty
mugen08
Outside the box
roarzorz
