2 18's or 3 15's?
Last set up is in sig
EDIT: Oh shit I forgot no more sig, haha
ED190v.2 18 Dual 2
SX1250.1 Pushinfg about 1400 at 1 ohm
JL 0 GUAGE
Stock batt
Ohh I hope it will Be, Shit If you dont think it will, Im tempted to get something else... What do you think this should Hit on termlab? Probabally 12 cubes or more, At 28HZ I want that Low tuning the first box, Im Sure it will be in there for a short period before I swap it out. haha. I think I would of hit a low 140 with the 18.
Im also thinking aobut Using aero ports, Firing right through rear deck, Actuall Flush mounted with the rear deck?
Will that work?
Ive never used Aero Ports, but I'd Like too
good luck coming from the trunk esp with an tuning as low as 28hz. if ur willing to loose some thing i get u like as twice as loud! then what ever u hit from the trunk.
Ahhh somone with the same problems as me. I have a 96 Grand Marquis. Im going with 4 CVR 12s, Im buildin the box this weekend. My metal wall is cut out, no 6x9s, no padding. Make sure you bypass or put foam over your fuel pump sensor in the trunk or it will set it off. How do you plan on porting through the rear deck with the box? All my boxes have been subs up/port back but this new one im gonna do subs and port back. How do you plan on porting up through the deck when your box will sit below the top of the gas tank most likely?
The box will start up there, It will take up the whole space below the rear deck, and then come down and take of the rest of the trunk, So I was goni to try to do that, But is doesnt look like I am gonig to be able and get the tuning right, So I have no idea Yet, Old box, wasnt in this car, It was In 05 CTS
Maybe Ill jsut take the whole ****ing seat out, and fire the port into cabin?
Would that work better, I can go Take pics now.
And 86yota, What exhaust do you have on your Car?
Ok, well the Subs are decided now, Looks like everyone agrees, Will be paid for in the next 2-3 days, So what should I so with amp?
I was thinking either the sundown SAZ1500, at .5 Ohm
Or 2 Nine.1's So each 3 subs is runing at 1 ohm
DeViOuSoNe
What's a Subwoofer?
DeViOuSoNe
MD
86yota
