(2) 15" Eclipse Ti SW9152 D4: (1) NIB, (1) LNIB
A.K.A. Spanyerd
200
Yuma, AZ
(1) N.I.B.
(1) L.N.I.B. - Nearly brand new. It has only about 4 hours of music on it (it wasn't over/under powered, I just wanted to see what it sounded like). The only marks are under the rubber mounting ring where the screws mount the sub.
Both are in the OEM boxes and packaging, along with the manual.
1500 wrms (each)
Up to 3" linear peak-to-peak xmax
Solid Titanium cone
2" Wide Polyether Surround
Dual Mirror Spiders
3" 4-Layer, Dual 4 ohm, Aluminum Voice Coil
Triple-stacked magnet
Removable motor/basket assembly
Specs shamelessly stolen from Audio_Phill's thread....
Re = 6.3646 ohms
Fs = 34.9878 Hz
Zmax = 92.7325 ohms
Qes = 0.6472
Qms = 8.7827
Qts = 0.6028
Le = 6.0781 mH (at 1 kHz)
Diam = 317.5000 mm ( 12.5000 in )
Sd = .0792m^2(122.7185 in^2)
Vas = 53.5213 L ( 1.8901 ft^3)
BL = 27.2810 N/A
Mms = 344.2702 g
Cms = 60.1046 uM/N
Kms = 16637.6641 N/M
Rms = 8.6172 R mechanical
Efficiency = 0.3328 %
Sensitivity= 87.2398 dB @1W/1m
Optimum Enclosures:
Either....
- 4.9net sealed for an F3 of 41.33
or.....
- 7net @ 23Hz for an F3 f 20.2Hz with 50sq" of port area. Break-in on 4net @ 27Hz on 1500rms.
My experience:
Excellent results can also achieved in smaller ported enclosures. Example: 5net @ 28Hz (F3 of 23.6Hz) with 60 sq" of port
$250 each, or both for $475. Those prices are for cash at pick up at 85367.
$290 shipped each, or both shipped for $550. Payment through PayPal only.
Prices are firm.
THE ONLY TRADE I WOULD CONSIDER IS FOR A SET OF ECLIPSE SC8365 COMPONENTS IN VGC + $$ FROM YOUR END.
I can deliver to El Centro CA for free, and anywhere within 100 miles of 85367 for $30 (gas money).
They'll ship FedEx, well-protected, double-boxed, and insured.
Refs:
- DIYMA.com
- 100% Ebay profile from 206 people over 8+ years: eBay Feedback Profile for yam_bag
SEE MY OTHER SUBWOOFER F.S. THREADS HERE....
http://www.caraudio.com/forums/subwoofer-classifieds/510333-sale-15-fi-btl-excellent-condition.html
http://www.caraudio.com/forums/subwoofer-classifieds/510410-dc-15-xl.html
http://www.caraudio.com/forums/subwoofer-classifieds/510345-cerwin-vega-stroker-15-d4.html
More coming soon...
im having a box built....2 cuubes after disp. tuned to 32
I know you're low on space as it is, but if you have a little more room to spare, the 9122 is optimal in 2.25 net @ 27Hz (F3 of 24Hz). If you aero-port you could recoup some of that additional space.
at 27? but its gonna be a single 12 in my trunk? im wondering how it will do
...im gonna use a simple kefred port tho no aero
---------- Post added at 01:53 AM ---------- Previous post was at 01:53 AM ----------
what about 30hz and still Bump for these beast asss 15's
Yeah, you're right. A single in the trunk should be tuned a little higher to get more out of it. 30hz through a kerf should do great. GL with it.
I was interested in those huge juggs a couple weeks ago when I offered to trade my Cerwin Vega S2000.1 + $$ for them. I've splattered my monitor 100 times since then thinkin about em, but I really need to move a sh*t-ton of subs ASAP. Thnx anyway.
well if you change your mind they are yours i really want these beasts
at 27? but its gonna be a single 12 in my trunk? im wondering how it will do...im gonna use a simple kefred port tho no aero
Im currently running an SW9122 in 2.3 @ 28hz in a single trunk it kills
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
827
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
A.K.A. Spanyerd
Yuma, AZ
    May 18, 2024
    May 18, 2024
