2 12's
maritoze
Jedi Master
340
CA
Ok so I've been debating quite a bit with myself:D, and I've decided to switch from my 2 15 AQ s2.5 to a pair of 12's. But I want the 12's to be louder than my two 15's I have now. I have them running off a BXi 2006d in a 6.9cube box ported to 35hz... Which 12's would you guys suggest to make this possible... Budget is abot 350 a sub( if need be) and of course I'll buy a new amp if its necessary. Thanks in advance for your help....//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Yeah Ill add more power. But Im trying to figure out which subs to buy, or maybe some 12's that can get just as loud.
2 hdc3 12's with around 4kw or more. u need alot more electrical and a much smaller box and a way better amp. try a 4 cube box tuned around 36 with 3 4" aeros or a 70 inch slot port it should be loud.
1.33 ohm for 6 d4's, strap a pair of 3kw amps. I thought about doing 5 in my box but it's tuned a little
low and I didn't want to go all out.
maritoze
Jedi Master
maritoze
CA
Notloud00
