2 12's vs 4 8's or 1 15
marcin93
so ive been wondering what should i get out of these three choices. Im looking for a loud SQL type set up. My choices so far are:
1: 15 inch T3 audio T.2000
2: Two 12 inch RE audio mx's
3: 4 8 inch sundown audio SA-8's.
These will be hooked up to a soundstream 2500d amp. A 18inch is out of the question because of its size, feel free to add your own ideas...
imo and based off quick winisd comparison, they are all gonna be pretty close. i would go whatever was cheapest. or if u want smaller box the 8s might do that(not sure as ive never designed a box for four 8s with port area included) but 4 sa8 only need 2.4-2.5 while two 12s and a 15 need 3.5 (before port displacement)
i would personally do two 12s or single 15, but the 8s would be different and surprise people
better not do the 4 sa-8s dangit..... i just finished my build of that same setup on an AQ2200. shiz pounds
They're actually pretty close. As an example, the 8" AA Assassin has a sd of 196cm^2, and the 15" Chaos has a sd of 810cm^2. So the comparison there would be 784cm^2 vs 810vs^2, which is really not even worth worrying about...because a dual 12 setup will give you around 960cm^2 of cone area. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
marcin93
marcin93
United States
marcin93
michigan born
    May 14, 2026
michigan born
    May 14, 2026
