2 12" kicker CompVR amp suggestions
XX95DSMXX
ok well i got 2 12" kicker CompVR dual 4Ohm now i need a new amp because i burned up my old amp...well i was looking at this amp here
Lanzar OPTI500X2
SPECS
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Line Outs for Left and Right Channels
Low Pass Filter Controls
High Pass Filter Controls
Subwoofer Remote Level Control
Power and Protection LED Indicators
Soft Turn On/Off
500 Watts x 2 RMS Power into 4 Ohms
1000 Watts x 2 Max Power into 4 Ohms
2000 Watts x 1 Max Power at 4 Ohms Bridged
750 x 2 Watts RMS Power into 2 Ohms
Minimum Speaker Impedance: 2 Ohms
THD: 0.04%
S/N Ratio: >100dB
Channel Separation: >60dB
Frequency Response: 10Hz - 35kHz
Variable Low Pass Filter: 50Hz~120Hz, 24dB/Octave
Variable High Pass Filter: 50Hz~750Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Input Sensitivity: 200mV ~ 8V
Fuse Rating: 40A x 4
Dimensions: 10.08" (W) x 2.12" (H) x 23.22" (L)
right now i have them wired so they are at 8Ohm and with both hooked to an amp it goes to 4Ohm right???
should i go with that amp or should i wire the subs so they are at 2Ohms and get an amp that is 500W X 2 @1ohm
or if you have anyother suggestions that would be great
also im not that good with this stuff so if ya need to ask me a question u can im me @ XX95DSMXX on AIM
ok i was looking at the specs for the kx 500.2 and it says it is 500w X 1 @4Ohm what would it be if i hooked up 2 to make a 4Ohm load what would the wattage be???
each sub will share the 500 watts at 4 ohm bridge (wired in series/parallel)
so each sub will be getting 250 watts give or take.
what kind of box are they in? sealed , ported
just wanna point out that you can't get a two ohm load with two dual 4ohm subs. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif .....its either 4 ohms, 16 ohms, or 1 ohm.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
917
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
XX95DSMXX
XX95DSMXX
mannington wv
Diplexers
