2 12"IDmax + DE1000?
hey will this amp run 1-ohm stable //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif and be capable of pushing two 12 inch IDmaxs?
You hace the answer to your own question:
2 Ohm Recommended Load
1½ Ohm Minimum Load
1000 Watts x 1 into 2 Ohms
In other words do what the manufacturer says and you won't have any problems.
And yes it will push two 12 inch IDmax at the recommended loads.
//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
but it says the minimum load is 1.5 ohms. so would that basically mean DO NOT RUN IT AT 1-ohm?? i don't want to send 1000 watts to two IDmax's cuz then they would be getting about 500 each right? i wanna see a higher figure with each sub.. say 800 watts to each and i'd be happy. =0) any suggestions?
1½ Ohm Minimum Load
have you called us amps and asked about being able to push YOUR DE-1000 to 1 ohm, i think not.//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
ok i have this amp and call then they told me that you can just make sure you have th ecurrent or this thing will go bye bye, they told me to either add anothe batt or to get a stronger alt, either way you can yes and i am planning on it personally to wire it down to 1 ohm. and yes thai should push 2 id maxes nicely
you rock. thanks.
noob with an RS
i poop on you
noob with an RS
earth
Bring97
