2 12" Funky pups sonosub build **not a joke**
What enclosure should i build for the pups? I will build what y'all decide!!
  • Total voters
    34
Ok so my thought is that i will route out the circles the right diameter for the tube and wood glue them in after i route out the sub cutout.... one on each side and 7 cactus 12k's on the way for power (or maybe a rockwood 1200 x 2max)?)
fixed your post
im almost tempted to purchase two for myself
it is truly amazing how whenever someone posts a link to funky pups people start to chime in about how theyre going to buy some so they can claim they have them
i dont think it would be worth my 50 just to say i have them, id use them. i hear 150watts is just the starting of it, anything under 150 is way under powering it. I was told if i get two of them i would then need two rockford t40001bd's two run them.
found this and found it funny
"Where can I buy a Funky Pup subwoofer?
I just got a new 13w7 and my friend said that a Funky Pup could easily take it. I have never heard of these and cant find any videos or anything."
check out the egay description LULZ
Only $24.95 for TWO new old stock [mfg in 2007 new unused] 12" woofers. ---- Rated 150 watts rms ---- 4 ohms. ---- 24 ounce barium ferrite ceramic magnets. ---- 1 1/2" voice coils. ---- 35hz to 4500hz response. ---- Ribbed poly treated paper cones. ---- Butyl foam surrounds. ---- Large 5 " rolled accordion spiders for long throw. ---- Deep draw pressed steel baskets. ---- Mount hole cutout required 11 1/16". ---- Mount depth 5 1/4". ---- 4 lbs each unboxed.
where do you even buy pups? i want like 6 of them soo bad
You have to go through Chuck Norris to get Funky Pups. Only he builds them, only his ears can take the abuse.
I'm thinking liquid nails for connecting the mdf to the sono? Any other suggestions for that connection? Ported or sealed people... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I just reconed my 13W7s to 13" Funky Pups. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
You should brace with adamintium dowel rods..........//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
My security clearance doesn't go high enough to access the funky pup t/s parameters. I've heard even viewing the extraordinary t/s specs of a...
18
Jaredturp
Jaredturp
PA
bigbangtheory
    May 12, 2024
Brendon Jenness
    May 11, 2024
