2 12" DC Audio Level 3s?
Well I'm sure the box id be getting would way more than 50lbs if its 5 cubes, and 2 of the level 3s would weigh 40 pounds together. And the amp I'd give em would prolly weigh in the 20-25 pound range. (most likely) but there are powerful amps that weigh less than that... The first extra battery I have weighs 50 something pounds... And add somewhere from 50-75lbs for the XS. I guess we'll see how the car does lol I think it'll be able to carry the weight. I was going to dynamat the trunk but now I've changed my mind, thatd add a lot more weight.
Deadener wont be a ton of wait... You could do level 2's?
I was running the Brutus 1700.1D @2Ohms (1200RMS) without the big 3, with just the yellow top and extra battery and I kept 14 volts pretty constant. I will admitt, it'll be an extra 600RMS drawing from the electrical, but I think the Big 3 could suffice or replace my current 2nd battery with a very highpowered XS.
I know i'm biased but the lvl 3 is a great sub both in sound quality(sealed or ported), and just getting down right smooth deep bass.
Box will be no where near 5 cu. They like 1.5cu ea with approximately 16sqin of port depending on whether or not your ground pounding or 18-24sqin for burps.
Eddie_24
Eddie_24
Ohio County, Kentucky
mylows10
