*2 10W7s or 1 12w7*********
limitkid7
sell wite
here's the deal
they'll (shop) allow me to trade up
they can give me 379 for my 12w6v2 pending on the condition
its brand new,
so then anyways -
i have the choice
2 10w7s' 459+459-379=539
1 12w7 = 750-379=371
i have 600 bucks to spend
what should i get........?????????????????????????
the subs will be ran off hifonics bx1500d ...
2 10s rms for the pair is only 1000 watts..... they'd be running @ 1.3 ohms thus giving each sub about 700 watts
1 12w7 - rms is 750 watts running @ 3ohms giving sub about 750 watts exactly....
try to make your decision w/o saying whether you'd go ported or sealed please.
Originally posted by Gauntlet I'd take the one 12" to save $$, but if you have no problem spending up to $600, then I'd say go for the two 10's.
ok 600 is what i'm gettin for my other 12's so i'm allowing that money to be invested in better subs.......
If i were you, i would do the two 10w7s. Port them, and they will be nice and loud. You wont be dissapointed. I have built two setups w/ two 10w7s. Incedently, both were in a grand cherokee. One setup was powered by a 1000/1 and the other was powered with a 500/1 on each sub. Both setups were extremely loud....and sounded **** clean. The 12w7 will have a loss in output over the two 10s. ALthough, the lower frequencies of the 12 might be a concern. But, the two 10s is an awesome setup in every way. Port those suckers. You will be suprised. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif The SQ will be phenomonal as well.
Originally posted by crhye250r If i were you, i would do the two 10w7s. Port them, and they will be nice and loud. You wont be dissapointed. I have built two setups w/ two 10w7s. Incedently, both were in a grand cherokee. One setup was powered by a 1000/1 and the other was powered with a 500/1 on each sub. Both setups were extremely loud....and sounded **** clean. The 12w7 will have a loss in output over the two 10s. ALthough, the lower frequencies of the 12 might be a concern. But, the two 10s is an awesome setup in every way. Port those suckers. You will be suprised. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif The SQ will be phenomonal as well.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Anyways, I'd go with the single 12" sub...simply because I'm fond of a single sub set up.
Originally posted by BDIDDY Why W7's?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
1st. He can trade in his w6 to get a lot of credit.
2nd. Basically best sub in the world hands down
limitkid I run 2 12W7's on an Orion 2500D and they run fine at full gain. those subs are under rated by JL. you want to push 1000-2000 WRMS into a single 12W7. well at least I do //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif cause then they hit soo hard!, because the W7's are one of the best subs for both SQ and SPL I would recommend 2: 12W7's. i had 1 in my lil S10 and it rocked that truck with a 300 2 channel amp. 1 on your amp should work really good. then someday upgrade and buy a second 12W7, then you rattle kitchen tables 5 blocks away //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
limitkid7
sell wite
limitkid7
GA
crhye250r
