2 10" or 1 13"
That’s a little over 4 cu ft total internal if using 3/4 mdf two 10s need about 3cu ft plus port so you should be fine with that space
Just went outside to remeasure and its 32W 16H 18D but can do 20D if needed. One sundowns sites it says they need 1.25 per woofer to 2.5 cubes net for the SA's
You’ll want to squeeze as much space as you can possibly spare ..polyfill sheet the interior and make sure subs are sharing the same chamber ...
IS350
IS350
Los Angeles, CA
IS350
    May 18, 2024
    May 18, 2024
