2.07 cubic feet too much for an HDC3 10?
IMOVeCHICKENS!
Firtyfwe here ngz
just curious with this airspace i get 40.8hz of tuning i could add port length is it's at 21.5 inches and i guess that would consume some of the airspace and lower my tuning is this a good idea?
or will i be fine with the 10 in 2 cu ft on an saz1500d at 1 ohm
with what you gave, and the assumption that you meant 21^3 inches of port, then your tuning is at 44.8hz and after displacement (of port and sub) your volume of box is 1.9 ft^3. If you lower your tuning by increasing port length, it will make the box more peaky with the given volume, and less of an even response.
well
port width 3 inches
port height 11.25 inches
port length 21.5 inches
so should i add some port length ive got plenty or resin and extra mdf laying around along with right angle brackets so anythings possible
Wooooah there, 2.07 is too much. You'd be much safer with 2 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
don't listen to me haha
IMOVeCHICKENS!
Firtyfwe here ngz
IMOVeCHICKENS!
727 FLA
IMOVeCHICKENS!
